Re: IH 656 Hydro pto, hydraulic and movement problem
Posted by pete 23 on August 15, 2012 at 19:19:23 from (74.32.238.2):
In Reply to: IH 656 Hydro pto, hydraulic and movement problem posted by shade2 on August 15, 2012 at 08:53:44:
You may have destroyed the hydostatic motor by pulling it with range trans in gear so you may have double problems now. You will have to remove bottom plate or top cover(which is not easy) of hydrostatic unit to see any damage to motor, and split tractor to tell anything about flex plate and shaft. Maybe with a bore scope you could get a look at splined shaft and flex plate but hard to see much through that little hole with naked eye.
