Re: Re: Super M cam gear nut torque spec
Posted by Bob M on October 09, 2000 at 05:08:27 from (192.232.120.194):
In Reply to: Re: Super M cam gear nut torque spec posted by ltf in nc on October 08, 2000 at 08:49:56:
ltf - Looks like the only part I'll have replace is the cam gear itself - hub and keyway on the old one is wallowed out pretty bad. The other timing gears are still in good shape - a chipped tooth on the governor idler and a few marks on the distributor drive gear. Also the keyway in the camshaft has a bad chip out of it. But I found that by using a new key, the new cam gear fits tight and drives the camshaft OK - even before the nut is run down. So I'm gonna try it with the camshaft as is (don't really care much to tear the engine down to replace the cam!)
Bob M
Post A Followup
: Re: Re: Re: Super M cam gear nut torque spec
