Re: Re: Re: Super M cam gear nut torque spec
Posted by ltf in nc on October 09, 2000 at 09:33:00 from (206.228.214.233):
In Reply to: Re: Re: Super M cam gear nut torque spec posted by Bob M on October 09, 2000 at 05:08:27:
Bob, When you get ready to put the gear on the cam apply some J B Weld to the side of the keyway where the damage is. I saw your previous pics and I had a similar problem and the J B Weld fix has held good for two seasons. Sounds as if you have everything under control. Good luck and thanks for the update.
Post A Followup
: Re: Re: Re: Re: Super M cam gear nut torque spec
