It's very common to replace the tel-a-depth valve with a common standard valve so it operates more like the earlier 300 and 350 tractors.
If you don't want to go there, you can hook it up to one of the other two valves. It's just the two hoses on the cylinder. Hook them to the ports on one of the other two valves.
The other two valves come out under the gas tank, so you will have to run hoses from there to the rear if there aren't any already.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
