mechanical advance, could be a 40 degree when u need a 23. if you have a M&W governor, it will open the carb up open at first, then close the butterfly just a tad when it settles in under load. those r famous for that. mechanical advance springs, could be too soft in tension, n kickin in the advance at high rpm, n weights r staying open till it idles down. can mess with ur timing under a load at different rpm n cause a hp loss. a 2 weight farmall governor will out perform a M&W governor on the dyno everytime, cause the 2 weight does not settle back when tuned in correctly. you wont see a rpm drop under load with the 4 weight on the dyno, just a power drop when it sets itself. you could have a worn throttle tip on the carb linkage, if its loose fitting, itll fluctuate the carb shaft position under full load. Ive seen these descriptions on the dyno, and thats what i found that cures it. stiffen up the advance, use a 2 weight governor, n make sure linkage is in good condition.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
