Re: I think I might have found my belt problem
Posted by Janicholson on August 19, 2012 at 16:32:34 from (96.24.99.126):
In Reply to: I think I might have found my belt problem posted by Brendon-KS on August 19, 2012 at 16:18:43:
That would sure cause it!! One issue is that a belt that has flipped ofer will take on a life of its own to flip. So if it works, fine, if it reflips, put a new belt on. Jim
