Re: C Countershaft Nut, Ring and Pinion Questions
Posted by TMatt on August 19, 2012 at 20:01:29 from (70.59.171.247):
In Reply to: Re: C Countershaft Nut, Ring and Pinion Questions posted by Haas on August 18, 2012 at 16:42:11:
Thanks for the reply.
Turns out there were two things causing my trouble. First, I found that the edge of the boss of 4th gear where it meets with the front bearing was badly worn.
Also I pulled out the spacer next to the rear bearing and found it had about an 1/8th inch groove worn in it too. I swapped these out and the pinion depth looks great.
Thanks again
