3 POINT WON'T MOVE ?
Posted by Brian Albright on August 20, 2012 at 14:23:06 from (64.128.201.68):
Please help. I have a1956 farmall 300 with live power? I bought a 3 point log splitter hooked it up to the ports under the gas tank and ran two lines back to the log splitter.Checked hydraulic res, then started the tractor to see if the splitter would move. it moved real slow and jerky. So then I shut the tractor off to check res and it was so low it would not register on the stick.So i filled res back up to try again nothing the three point won't even rase now? What did i do wrong? PLEASE HELP THANK YOU.
