Posted by mkirsch on August 21, 2012 at 06:19:30 from (64.80.110.74):
In Reply to: 3 POINT WON'T MOVE ? posted by Brian Albright on August 20, 2012 at 14:23:06:
A 300 does not have enough hydraulic reservoir to run a log splitter on its own. It only holds a couple gallons of fluid.
The typical 4x24 hydraulic cylinder on a 3pt log splitter will suck the reservoir dry long before it's fully extended. That's what happened here.
It requires 301 cubic inches, or about 1.5 gallons, of oil to extend a 4x24 cylinder. Plus whatever it takes to fill the hydraulic hoses. If your reservoir was down a little, most are, you sucked it dry.
Plus, with the constant cycling back and forth, and the force needed to split the wood, the oil will get hot quickly.
You need 5-10 gallons of extra fluid capacity. It needs an external tank that is connected to the fill pipe on the hydraulic reservoir.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
