Having been through a couple of diesel conversion exercises, I can tell you that pretty much EVERYTHING between the front bolster and the bell housing is different from gas to diesel.
This being a frameless tractor brings a whole new set of problems. On a tractor with frame rails, all you need is the correct front cover and rear cover for the engine and it will bolt right in. With no frame, the engine is what's holding the tractor together. You need to find out if the D239 block in the swather is the same block used in the tractor. The tractor block may have extra reinforcement, or special mounting points for the front bolster, cast in.
You're going to need the rear cover for sure, along with a flywheel and a whole different clutch. I'm guessing front cover also.
The radiator may be different too. IH liked to have the bottom outlet on one side for gas and on the opposite side for diesel.
Gas tank, throttle linkage, and wiring are the LEAST of your worries, and the easiest problems to overcome.
Ideally you will want a junk 574 diesel sitting in the next bay to harvest parts off of for your conversion...
If it's supposedly just the harmonic balancer on the gas engine, why don't you just replace it and get the gas engine running? Frankly, I think the whole harmonic balancer line is a bunch of baloney... Hope you didn't pay much for the tractor.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
