MTA Diesel just dies when switched over to diesel
Posted by Duanes on August 22, 2012 at 09:54:07 from (136.234.40.2):
Tractor starts and runs good on gas and when I switch over to diesel it just dies. When the tractor was put away last winter everything worked well. This spring I went to start it and started on gas but, acted like it was dieseling while running shut it down. About a month later when I had time I went to start it and starter would not work. We pulled started it on gas and it started and ran fine but, Gauge on injection pump would not show pressure. I had the starter fixed replaced both filters,cleaned water trap and cleaned filter in the side of the pump. Bled trap,aux filter and both had good diesel flow. Started tractor in gas moved engine speed lever into Diesel and bled final filter with good flow and then each injector individually and all squirted fuel at least 6' across the room. Any ideas what is wrong? Thanks!
Today's Featured Article - On the Road with Dave Gohl: Auction Musings - by Dave Gohl. I was thinking the other day about all the auctions I've been to in the last few years. There've been many. Some have been very good, some have been well, disappointing to say the least. But no matter how good or bad auctions may be, we always seem to stay until the item we've come for or are interested in is on the block. I've been to some auctions near and far. I think the furthest has been the Two Cylinder 7 in the Amana Colonies last year. Lots of stuff, lots of people. I've also atten ... [Read Article]
