Re: Adjustable main fuel jet.
Posted by rustyfarmall on August 22, 2012 at 11:16:54 from (67.55.162.174):
In Reply to: Adjustable main fuel jet. posted by Mr. farmall on August 22, 2012 at 10:39:26:
The adjustable jet does not replace the fixed main jet. It only allows you to decrease the amount of gasoline passing through it, and thus will provide a means of "leaning" down the fuel mix, but does not provide a means of "richening" the fuel mix.
I suppose you COULD drill out the fixed main jet slightly, and then use the adjustable jet to dial in the optimum fuel mix.
