Re: Fuel problem on IH 300
Posted by Phil Auten (TX) on October 10, 2000 at 04:13:36 from (206.175.72.226):
In Reply to: Fuel problem on IH 300 posted by Brian Schoenberg on October 09, 2000 at 15:13:26:
Brian,
I'm leaning toward Tractor Vet's diagnosis. If it's been running fine up until the cold snap I'd suspect icing closing off or restricting the carb just behind the butterfly. If the tractor runs fine after the weather warms up a bit, TV is right. If not, the other folks are. Just don't waste money trying to troubleshoot a problem that you won't be able to fix. Try it again when (if) the weather warms a bit.
My 2¢,
Phil
Post A Followup
: Re: Re: Fuel problem on IH 300
