Re: super A sickle bar mower
Posted by JRSutton on August 23, 2012 at 15:19:20 from (75.130.109.233):
In Reply to: super A sickle bar mower posted by DaveLamp on August 22, 2012 at 08:57:40:
Should be an a-21
And a-24 is the heavy duty mower - you can tell that one because it has two springs instead of the one.
The board isn't critical - any universal board, or one from a john deere will work just fine.
You can even just bolt on any old chunk of wood, it should work fine.
