Farmall A Model 16A Mower
Posted by Mike@NY on August 26, 2012 at 17:27:44 from (67.141.4.161):
Hello all;
I recently dug the mower that came with my father"s a out from under the shade tree. I intended on putting it on my 1944 A, but found that the pto shaft on my father"s 1942 A is the older smaller shaft and my 1944 A has the newer larger shaft. Did they make the 16A mower for the later A"s so I could maybe just find another PTO drive shaft that will fit the later A? I haven"t had any luck on e-Bay yet. I"d rather not have to modify the original if I don"t have to. Thanks for the help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
