Re: Farmall A Model 16A Mower
Posted by old on August 26, 2012 at 17:36:34 from (209.86.226.34):
In Reply to: Farmall A Model 16A Mower posted by Mike@NY on August 26, 2012 at 17:27:44:
That is a simple fix and any good farm and home place will have a PTO yoke you can just switch out to make your shaft the standard 1-38 instead of the older 1-1/8 shaft
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
