The wire you have running to the hot side of the coil can be there but there has to be a wire from the ignition switch to that post too. That wire is the exciter wire that when energized tells the alt to charge. It has the diode inline to prevent it from back feeding electricty and draining the battery when the engine is off. Without the diode it will backfeed enough that it willl feed the ingition system too not allowing it to shut off.
The wire on the other side of the amp meter has to feed back to the battery to charge it.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
[More Ads]
