Re: Help! Farmall 400 12v Conversion
Posted by mkirsch on August 28, 2012 at 10:56:56 from (64.80.110.75):
In Reply to: Help! Farmall 400 12v Conversion posted by TylerFarmallH on August 27, 2012 at 19:41:07:
One terminal from the ammeter should go to the + post of the battery, or the battery connection on the starter solenoid.
The other terminal from the ammeter should connect to three things:
1. Hot to the headlight switch
2. Hot to the key switch
3. Hot to the BAT terminal on the alternator
The 400 has a twist-key-to-start setup so the key switch will have two other posts:
A. Hot to the ballast resistor
B. Start to the "S" post on the solenoid
The ballast resistor will have two connections:
I. Key switch side to diode and on to the alternator's #1 terminal
II. Open side to + post on coil, - side of coil to distributor
If it's hooked up that way and still doesn't work, check your work again because it isn't hooked up that way. Either that, or you have gremlins.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
