Re: IH transmission and clutch
Posted by Phil Auten (TX) on October 11, 2000 at 06:43:26 from (206.175.72.226):
In Reply to: IH transmission and clutch posted by H. Stroh on October 11, 2000 at 05:58:45:
If this happens while using the TA in the low position, it's probably the TA clutches slipping.
Phil
Post A Followup
: Re: Re: IH transmission and clutch
