Re: Re: IH transmission and clutch
Posted by Stan(VA) on October 11, 2000 at 08:23:03 from (207.172.106.151):
In Reply to: Re: IH transmission and clutch posted by Phil Auten (TX) on October 11, 2000 at 06:43:26:
Phil,
I thought the TA gave an under-drive, so wouldn't the clutch be used for direct and the gear reduction be used when in low range? Sorry if that's out to lunch, I don't have a TA in any of mine;)
Stan(VA).
Post A Followup
: Re: Re: Re: IH transmission and clutch
