Re: 12 v alternator
Posted by Janicholson on August 29, 2012 at 08:24:33 from (199.17.6.20):
In Reply to: Re: 12 v alternator posted by mkirsch on August 29, 2012 at 05:31:28:
If the watts are the same or close it will work fine. If the bulbs are not changed it will blow. If Diode lights like Colby560 is using it will probably also work. Jim
