Posted by Janicholson on August 29, 2012 at 12:32:39 from (199.17.6.249):
In Reply to: clutch installation posted by BigTone on August 29, 2012 at 12:13:01:
If the engine is installed, and the clutch shaft is through the disk into the pilot bearing yes. If you take the compression bolts out with no shaft in it, the disk will be way out of alignment, and the shaft will not stab through, the disk will bind and possibly bend on the splines. Remove those three bolts after the clutch shaft is installed and tied to the drive yolk. into the trans. Using the shaft to align it ahead of time is OK, but the best is to let it be loose till the engine is fully attached, as that allows the greatest degree of freedom when putting it together. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
