highr low idle
Posted by morris roessler on August 30, 2012 at 08:17:26 from (69.163.6.36):
can someone put a bug in my ear about how to adjust the high and low idle on the 706..263 gas. When I fisrt start it cold with throttle at idle position it will idle around 1500 rpm, when it is warmed up and I speed her up some and then slow it back to idle, it runs so slow I can almost count the fan blades,but keeps running very well.Could someone tell me how to just this idle situation proporley. It would be greatly apreciated.. Thanks Guys... Morry
