Re: IH 404 Utility Hydrualic Problem
Posted by clay mcnamara on August 30, 2012 at 16:37:11 from (184.158.13.228):
In Reply to: IH 404 Utility Hydrualic Problem posted by clay mcnamara on August 30, 2012 at 11:55:53:
Yes did filter. Does the 404 use the transmission cavity as a sump? If so, how does it get the fluid from the trans up to the feed / return lines? It seems like the feed line to the pump is up so high?? Is there a different reservoir? Where do you fill it up at? Thank you.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
