Re: IH 404 Utility Hydrualic Problem
Posted by gene bradley on August 30, 2012 at 17:49:39 from (173.216.227.180):
In Reply to: Re: IH 404 Utility Hydrualic Problem posted by clay mcnamara on August 30, 2012 at 16:37:11:
clay yes the trans. diff. & hyd.are all together you see the problem the hyd. pump is higher than the oil level use hy-tran oil now other methods to bleed system get rear wheels as high as safe possible back up on something solid - curb -sidewalk or bank you can drive into a ditch but be careful run motor pretty high & work lift control up & down there is no screen on pickup tube in friendship gene bradley fill plug in front of seat only 1!
