Posted by New2supers on September 01, 2012 at 08:10:41 from (74.67.75.62):
would you guys reuse the original pistons? rings are stuck sleeves are out. block , crank and internals beautiful shape. towed with very good oil pressure so i am assuming the mains are good.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
