Re: 300 starter relay update
Posted by Zachary Hoyt on September 01, 2012 at 14:01:08 from (184.12.70.98):
In Reply to: Re: 300 starter relay update posted by D Slater on September 01, 2012 at 12:30:35:
I went ahead and switched the wires and now everything appears to be working as it should. I have no idea why, but it seems that way. With the battery voltage on the terminal next to the S terminal the I terminal had 12v at all times, with the wire switched to the I terminal side the I terminal does not have voltage when I check it. I am not able to keep a meter on it and press the start button at the same time so that will have to wait till there is someone here to help. I am mystified but as my old boss used to say "Don't argue with success."
Zach
