Re: 300 starter relay update
Posted by D Slater on September 01, 2012 at 12:30:35 from (184.15.8.74):
In Reply to: Re: 300 starter relay update posted by Zachary Hoyt on September 01, 2012 at 11:01:22:
Don't think it will help. Shouldn't be voltage going from the relay switch to the I terminal unless the switch engages the starter.
If the tractor starts good without the wire from I to coil you could drop it.
Lots of H and M tractors are changed to 12 volts without the wire bypassing the resister.
This post was edited by D Slater at 12:37:21 09/01/12.
