Re: 806 pto
Posted by The tractor vet on September 03, 2012 at 17:06:48 from (76.212.232.42):
In Reply to: 806 pto posted by 1349 on September 03, 2012 at 15:02:22:
Well the ONLY WAY to install the little pin is to pull the hitch support and remove the plug and drop the valve out the bottom THEN you install the pin and you make the two halfs one LONG valve and reinstall from the bottom . Then ya need to reset pressure and here ya need the special hyd. fitting and a gauge that will read 600 LBS. and you need to do this with the hyd.oil at operating temp . Iset them to 235-245.
