Re: International 966 TA Not Working
Posted by 756puller on September 05, 2012 at 04:18:21 from (96.31.184.142):
In Reply to: International 966 TA Not Working posted by Beatles65 on September 04, 2012 at 21:26:17:
the check valve just lets oil in to the steering system incase of a dead engine so that you can at least attempt to steer if needed, sounds like you need to get a couple of pressure gauges and test ta lube pressure and the clutch pressures for the ta sounds like there could be a blown gasket or oring, maybe go thru the whole valve checking springs and orings
