I tried all those things- 3rd set of plugs- new points/ condensor times. Air leak would make it those cylinders run lean- dont know what else to do. Valves are timed and compression is great- good oil pressure
leaves 2 things spark and fuel. Been through he carb atleast 4 times now. No change. I can get it to run lean enough as long as I adjust the main fuel mixture to the load I'm working at but put her to idle or anything other than that load and its too rich. or If I adjust to putt mode its too lean at higher speeds.
gonna try a coil and check all ignition wires and give it a shot.
Only thing im thinkin is the carb jets were drilled and wrong needles were reinstalled before I got it. I dont know how to check jets
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
