Re: Hot Coil?? is it bad.
Posted by old on September 05, 2012 at 10:28:32 from (209.86.226.30):
In Reply to: Re: Hot Coil?? is it bad. posted by NolanJae on September 05, 2012 at 07:42:28:
Trouble shoot first then parts not the other way around.
Check you spark. Make sure it is in fact a blue/white in color and will jump a 1/4 inch gap or more. If it will not do that then try cleaning the points and check again. If it still is not good jump across the ballast resister and check. Good then you coil is most likely weak. Also look at the bottom of your coil. If it is pushed out good chance you got it to hot if still flat not likely to be bad
