From whaty i am seeing and that is not much in the pour picture is that if you did not see a little spring and a nylon check valve that looks like a mushroom with a handle on it in the lower right hand corner what i am seeing here is a sump check plug where the hole for the check valve is suppose to be . and did you replace the O/Ring on the lower left along with a new gskt?? . Is there a blowen gskt between the plates on the MCV or blowen O/Ring in there ? I have no idea what you had before and setting here trying to second guess as what is wrong makes it hard to try and tell you where your problem is. And NO i am not making a service call out that far.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
