Re: volt drop across coil?
Posted by JMOR on September 05, 2012 at 16:47:02 from (72.181.173.171):
In Reply to: volt drop across coil? posted by Tom Fleming on September 05, 2012 at 16:43:04:
Quoting Removed, click Modern View to seeUnless someone has stuck a resistor in line somewhere, you should be seeing full battery voltage when stalled, points closed, ign ON.
