volt drop across coil?
Posted by AF70 on September 05, 2012 at 16:43:04 from (66.142.221.86):
Working on an old H with a 6 volt Delco distributor/coil but coil doesn't look like an IH coil. Has been running OK but now a sometimes non- starter. There's about a 1 volt drop between the switch side and distributor side of the coil. Is that normal? Thanks!!!
