Rear Remotes on SH Stage II
Posted by Va Gasman on September 05, 2012 at 17:12:17 from (75.243.87.177):
I have two remotes on rear of SH that appear to be factory originals. They are brass quick disconnects. They are oil tight and kick when the valve is opened. Are these IH and can you still find the other half of adapter? What is there is a female thread with a red center that may be a valve plunger.
