Re: Rear Remotes on SH Stage II
Posted by mkirsch on September 06, 2012 at 05:28:48 from (64.80.110.74):
In Reply to: Rear Remotes on SH Stage II posted by Va Gasman on September 05, 2012 at 17:12:17:
Is it "two remotes" as in two hoses?
Is it "two remotes" as in FOUR hoses?
To truly have "two remotes" you need four hoses. Two hoses per remote for two-way hydraulics.
If you want to use the tractor, it would probably be best to just upgrade to modern Pioneer style couplers. Pioneer style couplers are pretty much the universal standard these days.
