Re: volt drop across coil?
Posted by Janicholson on September 05, 2012 at 18:20:48 from (96.24.99.126):
In Reply to: volt drop across coil? posted by AF70 on September 05, 2012 at 16:43:04:
Points ground the coil. When the points are closed, there should be no detectable voltage at the distributor side of the coil from the terminal to ground. When the points are open, with a good condenser, the voltage at the distributor side of the coil should be full battery voltage. The 2 to 3 ohms of resistance through the coil do not drop the voltage on an open circuit (like it is) enough to change the voltage reading on a Multi meter.
So basically you cant measure the voltage drop and make sense out of it. In simple terms it is just like measuring from the block to the key with the points closed, and the low internal resistance allows a sensitive meter to read battery voltage right through the unloaded coil when the points are open.
When the points are open the coil should read between 2 and 3 ohms measured across the little terminals Jim
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
