1950 H live hydraulic pressure
Posted by Gamehunter56474 on September 08, 2012 at 09:28:24 from (96.60.152.38):
I recently installed a f-300 hydraulic pump on the old girl. Works great, love it. Problem, I have Prince stackable valves on it. The inlet has adjustable relief valve on it. The lowest setting is 1500psi. Sounds like to much to me. What is the factory pressure from super H, 300,350 hyd. pump. I have enough pump pressure to completely choke off the motor at half throttle, not good. Is the stock relief valve on the inlet suficiant.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
