Re: 1950 H live hydraulic pressure
Posted by Bob M on September 08, 2012 at 10:05:25 from (74.67.190.208):
In Reply to: 1950 H live hydraulic pressure posted by Gamehunter56474 on September 08, 2012 at 09:28:24:
Factory pressure for the SH live hydraulics is 1,200 psi. You can swap in a lower spring rate (softer) spring into the relief to lower the relief setting. Or plumb an external 1,200 psi relief valve into the pump outlet.
You should do this ASAP - especially if your H still has the original cam drive gear! The load you're putting on it when dead-heading at 1,500 psi carries a high risk of breaking the gear.
