806 RD pump
Posted by Bob3 Martin on September 08, 2012 at 15:29:09 from (71.7.75.192):
Working some of the leaks out of this pump. This forum has been such big help in the process.
I"m down to one final leak around a knob affair that sits under the pump itself to the rear of the drain plug on the fuel bowl about five inches. You can turn it about a quarter turn and it has a boot on it.
The boot is all but gone and there is an "0" ring on the stem up in the pump. I need to remove that knob thing with the stem to get at the "0" ring to replace it. I don"t see any nut to remove. Is there a trick to pulling it out to replace that "0".
Appreciate the help, as always.
Bob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
