Re: 806 RD pump
Posted by pete 23 on September 08, 2012 at 22:45:34 from (74.32.238.2):
In Reply to: 806 RD pump posted by Bob3 Martin on September 08, 2012 at 15:29:09:
To get that plunger out you have to take the primary pump off and there is a retaining pin you pull out from the inside.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
