Re: 806 PTO fixed
Posted by mazemeister on September 08, 2012 at 16:36:51 from (24.187.98.163):
In Reply to: Re: 806 PTO fixed posted by The tractor vet on September 08, 2012 at 14:42:25:
course, the problem COULD be leaking seals in the pressure circuit inside the pto assy, but if the linkage is worn, try building up the worn spots with weld, grind down to fit the holes a little more snugly. even fancier would be on a lathe, but by the time the tractor is this old, you can be pretty rough and still make it a whole lot better than it was.
