Re: 806 PTO fixed
Posted by The tractor vet on September 08, 2012 at 14:42:25 from (76.212.230.88):
In Reply to: 806 PTO fixed posted by 1349 on September 08, 2012 at 14:19:12:
IF you are having trouble getting the pressure then do this. Loosen the two 1/2 inch bolts that hold the linkage bracket to the PTO unit and pry up the bracket and hold it up while someone tightens it up . This should get you about 40 lbs more . Ya don't want to run it that low as you will walk thru the clutches. under load . If you egg shape the holes in the mounting bracket a little on the bottom side it will help . Due to age and ware your not getting the LIFT on the valve .
