W450 Hydraulic Lift Problem
Posted by Woody H. on September 09, 2012 at 20:19:49 from (107.40.201.16):
My neighbor has a Super MTA that he uses to pull a triple deck folding finish mower and everything works fine. He also has a W450 that he tried to use and the hydrulics would only lift the rear center deck. We checked the pressure at the disconnect on the Super MTA and got 1550psi. We checked the pressure at the disconnect on the W450 and only got about 1100psi. Not sure if the pressure on the W450(double cylinder) should be. Have read about some of these losing a the prime but have not seen that discussed in the manual. The mower has a Pioneer fitting that does work fine when hooked to the Super MTA. Thanks for any and all help.
