Re: Farmall 300 power steering conversion
Posted by Janicholson on September 10, 2012 at 20:24:59 from (96.24.99.126):
In Reply to: Farmall 300 power steering conversion posted by Mark Koran on September 10, 2012 at 07:40:41:
I can explain that the use of a belt driven pump is probably going to be easiest. The factory setup uses a priority valve in the valve cluster, and "U" tube to connect parts and it is far less work to put a Honda power steering pump with remote reservoir on a bracket than tearing into the stock hydraulics. Jim
