Re: Farmall 300 power steering conversion
Posted by Mark Koran on September 11, 2012 at 06:02:32 from (184.197.107.145):
In Reply to: Re: Farmall 300 power steering conversion posted by Janicholson on September 10, 2012 at 20:24:59:
Thanks Jim, Would using a separate power steering pump eliminate all of the complexities of installing the priority valves in the factory set up? If so, would the power steering pump connect directly to the power steering unit? Is there enough volume produced by a honda pump? I"ve read the power steering unit requires 3 gpm. I like your suggestion because I also have a loader on the tractor. I appreciate the help.
