Re: Super M upper bolster seal
Posted by glennster on September 13, 2012 at 05:43:12 from (75.57.143.173):
In Reply to: Super M upper bolster seal posted by 47 Bill on September 13, 2012 at 01:19:18:
carter and gruenenwald (sp?) sells the complete kit to rebuild the bolster. has upper and lower bushings, lower bearing, seals and steering shaft bearing, bushing and seal.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
