Super M upper bolster seal
Posted by 47 Bill on September 13, 2012 at 01:19:18 from (173.166.167.77):
How does one change the oil seal on the upper bolster pivot shaft? (The one that keeps your gear oil from running down the pivot shaft). Does shaft have to come all the way out? Can it be dropped part way?
How do you remove and re-install seal? From parts photo looks like installed from bottom of casting. Any info appreciated.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
