Re: Super M upper bolster seal
Posted by Fullers Farmalls on September 13, 2012 at 08:28:16 from (158.83.118.87):
In Reply to: Super M upper bolster seal posted by 47 Bill on September 13, 2012 at 01:19:18:
I just had mine apart. I put corn head grease in the box. It keeps its nice and oiled up but doesn't run down the pivot shaft at all.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
